DIAdem
Transferring data between user dialog boxes
Hello!
I'm working on a GUI in DIAdem that I can use in measurement data evaluation. Currently I have a main dialog box, where I can select which channels I want to display in DIAdem View. I want to create a sub dialog box with a table where I can type in upper and lower limits for the selected channels, and display these limits as constants along with the channel signals. Is there any way I can reach the contents of the sub dialog box from the main dialog box?
Akos
(3,152 Views)
My approach to this has been to define an object to store the data I wish to transfer from a dialog to a calling script and pass that object in with the SUDDlgShow; the dialog then modifies and passes that object back to the script when the user is done with the dialog.
calling script:
dim oDialogInterface: set oDialogInterface = new DialogInterfaceClass
call SUDDlgShow("DesiredDlg", "dialog.SUD", oDialogInterface)
then the dialog contains these two events to handle this passing of data: Dialog_EventInitialize and Dialog_EventTerminate. They work something like this:
Sub Dialog_EventInitialize(By Ref This)
set oDialogInterface = This.GetArgument()
End Sub
Sub Dialog_EventTerminate(ByRef This)
call This.SetArgument(oDialogInterface)
End Sub
Hope this helps
(3,117 Views)
Thanks for your reply jcopetre.
Meanwhile I used a different approach with global arrays. Based on the selection in dialog box 1, I put the selected items in an array, then in dialog box 2 I could access the contents of this array.
Akos
(3,091 Views)
