DIAdem
Trying to define multiple versions of one variable from input box
I am trying to Dim variables that have different numbers of iterations each time I run a script.  However, I don't think I can use a variable within a Dim statement.  Is there another way to do this?
What I think I want to do is this:
Dim n, xsum, xavg
xsum=0
xavg=0
m=InputBox("How many runs should be averaged?")    'For example, m = 3
n=m-1 'Convert number of runs to base zero; for example, n = 2
Dim x(n)
For i= 0 to n
x(i)=i
Next   'For example, x(0) = 0, x(1) = 1, x(2) = 2
For i=0 to n
xsum=xsum+x(i)
Next   'For example, the completed xsum = 3
xavg=xsum/m  'For example, xavg = 1
Steve Aykens
9172 8-slot cDAQ chassis OR 9162 cDAQ USB carrier
9234 4-Ch IEPE Sound/Vibration Input Module
9219 (2) 4-Ch Universal Input Module
9213 (3) 16-Ch Thermocouple Input Module
Signal Express 2012 with Sound and Vibration Suite
Labview 2012
DIAdem 2012
(4,674 Views)
Accepted by topic author sraykens
Hi sraykens,
ReDim x(n) should work.  I always Dim my variables as scalars and use ReDim to turn them into arrays when needed-- it works out better for several reasons.
Brad Turpin
DIAdem Product Support Engineer
(4,666 Views)
