DIAdem
UTF-8 support in DIAdem 15 / DIAdem 15 GIT support
I am working on a DIAdem project and I use the GIT to version my files. It seems DIAdem uses defaultly UTF-16LE encoding, which makes GIT treat the files as binary. So when making commits I don't get any change logs, only that the files differ.
So I manually changed all the files to UTF-8. But now the DIAdem behaves strangely:
  • Some letters are not shown correctly now => e.g. '?' gets shown instead of Δ, sometimes weirder letters.
  • When I fix replace this letters in DIAdem the script runs fine and in the reports I get the correct letters.
  • When I close the file and open it afterwards, some letters get destroyed again. (‰ and ° seem to work after the first fix, Δ not)
What do I do wrong? Does DIAdem not fully support UTF-8? If not, how should I version the files using GIT and still have the file comparisons? I tried some suggestions found online, but they did not work for me.
(3,649 Views)
After some research, I can present you with two possible solutions for your issue:
  1. It is possible to change encoding in DIAdem from Unicode to ANSI – Every character will be encoded as an ANSI character and special, non-standard characters will be replaced with “?”.
  2. Install some third party software plugin for GIT, which might allow GIT to view, read and compare files encoded in UTF-16.
I am also attaching illustrative instructions how to change encoding.
Please, let me know if the answer was helpful.
Best regards
FH
(3,609 Views)
Sadly the provided solution (first point) did not help.
When I use the ANSI Diadem encoding and use the Δ sign it seems to work, but after closing and opening the file again, the Δ gets replaced by '?'.
(3,579 Views)
Accepted by topic author SeryDavid
Solved this problem by adding:
into .gitconfig:
[diff "utf16le"]
    textconv = "iconv -f UTF-16LE -t UTF-8"
into .gitattributes:
*.vbs diff=utf16le
*.VBS diff=utf16le
(3,568 Views)
