DIAdem
Unable to copy text from logfile
Diadem Script, down is a window with logfile.
Sometimes i cant copy text from there, i mark some output and want to copy it with CTRL+C but it doesnt work, sometimes it works.
Sometimes help if i click "open in editor" and in new script tab it works.
Diadem 2017 64bit, windows 10
(2,312 Views)
Just chiming in to say I've noticed the same behavior.
(2,250 Views)
Hi Lukas, Julia,
Yeah, I also noticed several DIAdem versions ago the log file view at the bottom of the SCRIPT panel sometimes doesn't allow you to copy from it with <Ctrl-C> so you can paste the content elsewhere.  I could have sworn that that always used to work.  Of course, I just tried it in DIAdem 2019, and it worked right away, so I don't know what's triggering it.  I've always been able to right-click and choose "Open in Editor" and then copy from the new window, though.
Has one of you mentioned this in DIAdemIdeas?
Brad Turpin
DIAdem Product Support Engineer
(2,217 Views)
