DIAdem
Unexpected behavior using differential range type REPORT object
Hello, I am experiencing some undesirable behavior with a 2D graph in REPORT, using DIAdem 10.1 or 10.2.  I have three curves that I wish to display in "differential" mode with a "range" rather than "bars"  If I use an offset > 0, the horizontal bars are offset, but not the vertical bars 😞 This is not pretty.  Am I doing something wrong?  The "bars" mode works fine by the way.  I am attaching sample data and my REPORT layout.
(3,350 Views)
Hello Julia,
Unfortunately you are right. Curves displayed with the "differential" mode as a "range" can not be used with an offset. As you already mentioned the "bars" mode works fine.
I've created an entry in our database so that this problem will be fixed.
Thank you and greetings
Walter
(3,334 Views)
