DIAdem
Unexplained Line On Graph
We are using DIAdem 9.0. I have a single curve on a graph. Please see the file "The Graph"
Notice the diagonal line from the top of the Y axis to the left of the X axis. This line does not appear in the editor. If you export the graph to a *.bmp file, it will show up. It also appears on all the printers I've tried.
File "The Files" contains is a zip file with the *.tdr and the data channel to recreate this.
I appreciate your help.
(4,057 Views)
I have tried this in DIAdem 9.01 with you files, printed to BMP and laser printer and found no problem.
Please download and try version 9.01:
http://digital.ni.com/softlib.nsf/websearch/01A92A27DC1D22E786256E7D007C6496?opendocument&node=132060_US
Let me know if this doesn't help and I will investigate further.
Otmar
Otmar D. Foehner
(4,057 Views)
Hi DIAemon;
Try moving your Y axis to the axis origin. Right now your axis origin is set to the middle of the X axis.
That should clear up the display problem, but it looks like the first datapoint you are plotting has a time value that is not right. I would check this also.
Let me know
Tom
(4,057 Views)
That's a known issue in the version 9.0.
I'd recommend you to install the update 9.01, it includes a fix for this problem.
The update is free and can be downloaded here:
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C104B?opendocument&node=132070_US
It's a complete version of DIAdem. Thus you'll have to deinstall 9.0 first and activate 9.01 then as you did with your actual version.
Ingo Schumacher
Applications Engineering
(4,057 Views)
Thanks for the fast response. 9.01 worked great !
(4,057 Views)
