DIAdem
User Defined Format Numbers in Report Table
Hello All
I have a report template which displays a numerical channel of numbers.
Normally I format the column in the table to display only 2 decimal places.
This usually suffices however there are instances were I have a very small negative number (For example -0.00004624) and when I format the column display to 2 decimal places (d.dd) I get -0.00 which confuses some of my clients.
Is there a way to use the user defined category to round the entire channel which would eliminate the -0.00 condition.
In addition please keep in mind that the data in the portal that the table column object references cannot be altered nor do I want to create any additional copies of the original data.
Tim
(2,606 Views)
If you are expecting no negative values, you can use "abs d.dd"
And here is the reference
http://zone.ni.com/reference/en-XX/help/370858P-01/genpresent/genpresent/genreport_format/
(2,599 Views)
This will have to suffice for the time being.
Tim
(2,566 Views)
