DIAdem
Using ExcelExport without opening the dialog box to select all the channels in portal by default
    I need to export all the data in the Data portal to an Excel file without opening the Dialog for channels selection. In the ExcelExport command, it asks for a Config (*.stp) file as one of the parameters. Is there need to create a new stp file for selecting all channels or can the same file (Example_ASC.stp ) be reused ? If so, do I need to change any content in the system stp file ?
Venkatesh Murthy
(3,402 Views)
