DIAdem
Using ScriptStart in VC++ doesn't seems to be working.
I am a software a developer.  I am using Diadem 9.x evaluation version.  While I try to run Scriptstart function in VC++ using OLE.  It seems its failing.  The below is the code sequence.
Please help,
ITOCommand dispToCmd ;
COleVariant oleVariant;
if( dispToCmd.CreateDispatch("diadem.tocommand", err) == FALSE)
pServer->m_log << "DIAdem Instancing Failure. \n";
throw err;
dispToCmd.SetBNoMsgDisplay( TRUE );
pServer->m_log << "Message display disabled in DIAdem. \n";
dispToCmd.SetBNoErrorDisplay( TRUE );
pServer->m_log << "Error display disabled in DIAdem. \n";
Sleep(4000);
oleVariant = _T("");
oleVariant = _T("T1:='"+ _bstr_t(pServer->m_strJobId) +"'");
oleVariant = _T("ScriptStart('D:\\Test.VBS')");
CoUninitialize(); // Uninitialize the COM Library
Subbaraj.
Message 1 of 26
(7,835 Views)
Hello Subbaraj!
I'm missing a call to 'CmdExecuteSync' or 'CmdExecuteAsync'.
Try this code before CoUnitialize:
oleVariant = _T("ScriptStart('D:\\Test.VBS')" );
dispToCmd.CmdExecuteSync(oleVariant);
My Test with 9.1 were successful!
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
Message 2 of 26
(7,828 Views)
Sorry for that copy-paste error,  The code was already there.
This seems not working,  Is it because of Evaluation version of 9.x ?
I am trying to open a text file and write some information using VB Script.
Please suggest.
Subbaraj.
Message 3 of 26
(7,815 Views)
Hello Subbaraj!
If DIAdem is already running and the evaluation dialog is closed this should be no problem. You can ensure that DIAdem is able to process OLE commands by waiting for the interface flag 'bInterfaceLocked' to be false before the first 'real' call.
Matthias
Matthias Alleweldt
Twigeater?
Message 4 of 26
(7,812 Views)
Matthias:
I have a similar problem.  I am running the same code, and it fails on the dispToCmd.CreateDispatch statement:
throw err;
Do you, or does anyone have an idea how to fix this.
Tom
Message 5 of 26
(7,603 Views)
Hello Tom!
Have you run DIAdem with admin rights after installing? This is necessary to register the DIAdem OLE Server.
If you did it please try this  VBS code in Windows (Paste it to a file with a vbs extension and doubleclick it in the explorer):
Option Explicit
Dim oToCommand
Set oToCommand = CreateObject("DIAdem.ToCommand")
You can also check the registration in the registry. Try to find out if this Key HKEY_CLASSES_ROOT\CLSID\{285E4FB2-F633-11D1-85DC-008048D9A408}\LocalServer32 exists and its value is your DIAdem executable.
Matthias
Matthias Alleweldt
Twigeater?
Message 6 of 26
(7,597 Views)
Matthias:
Thanks for the reply!
I am running as admin.
I ran the script that you sent, but did not see any output.  It ran for about 12 seconds and consumed memory and CPU.
The key that you questioned is in the registry.
Tom
Message 7 of 26
(7,595 Views)
Matthias:
When I run the VBS script as you recommended, Diadem starts, and then exits after about 12 seconds.
When I try to execute my code, Diadem starts, runs for abnout 12 seconds, and does not exit.  I have to use task manager to end the process.
Tom
Message 8 of 26
(7,590 Views)
Hello Tom!
The script does the same as your C++ code. No output means no error! The time is consumed because DIAdem is started in the background. At the moment I have no idea anymore what causes your C++ code to crash. I have a test program in my office. I will try it tomorrow and give you feedback.
Matthias
Matthias Alleweldt
Twigeater?
Message 9 of 26
(7,589 Views)
Hello Tom!
Can you please try this code instead and report the content of the messagebox:
COleException oEx;
if( dispToCmd.CreateDispatch( (LPCTSTR)_T("diadem.tocommand"), &oEx) == FALSE)
  oEx.ReportError();
  return;
Matthias
Matthias Alleweldt
Twigeater?
Message 10 of 26
(7,565 Views)
