DIAdem
Using channel index in command datafilesavesel doesn´t work
I want to export all channels from the group "MinMaxCurves". I´m using following command which should work:
DataFileSaveSel("C:\MinMaxCurves.csv", "CSV", "'MinMaxCurves/[1]' - 'MinMaxCurves/["&str(GroupChnCount(GroupIndexGet("MinMaxCurves")))&"]'")
But I get this error message:
"Im Befehl "DATAFILESAVESEL("C:\MinMaxCurves.csv", "CSV", "'MinMaxCurves/[1]' - 'MinMaxCurves/["&str(GroupChnCount(GroupIndexGet("MinMaxCurves")))&"]'")" kann der übergebene Text "5-4" des Aelektionsparameters nicht fehlerfrei interpretiert werden."
Normally Diadem should use the index from channels. But instead of using the index, Diadem use the numbers. 5 is the number from my first channel and 4 from my last channel. I also tried out ExtendChnName = "NameIndex" command.
Why Diadem won´t use the index?
Regards
Marcel
(3,843 Views)
Hello Marcel!
IMHO this is a bug in DIAdem. This occurs if the channel numbers are not in an ascending order in a channel group. The only solution I know is a previous call to the command 'ChnRenumber'. But this will change all channel numbers! No problem if you access the channels by name.
Matthias
Message Edited by Twigeater on 07-07-2008 05:01 PM
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,841 Views)
Hello Matthias,
thank you for your help. Now it works!
Regards
Marcel
(3,836 Views)
