DIAdem
Using the Previous Row in a Calculator Formula
Hello.  I am using the calculator to create a new channel that is a custom filtered version of an existing channel.  Unfortunately, I have not been able to identify the previous row entry in the channel.  To make things easier, let's say my filter is a simple averager.  Here is simple pseudocode for what I want to do:
New_Channel = (Existing_Channel[n] + Existing_Channel[n-1]) / 2
where n is the current row.
This is the calculator formula I have come up with:
ch("[1]/New_Channel") = (CHD(chnRow - 1, "[1]/Existing_Channel") + ch("[1]/Existing_Channel")) / 2 + CTNV(chnRow > 1)
Unfortunately, I think chnRow only returns 0.
Obviously, I am a beginner.  I am open to other approaches to creating a new channel with a custom filter.
Thanks!
(5,363 Views)
Accepted by topic author jbuttron
Hi jbuttron,
What you need to do is to copy the channel and delete the first value from the copied channel-- then the Nth row of the original channel will line up with the (N-1)th row of the copied channel.  You should also add the last value of the copied channel to the end of that channel as a new value so both channels end up with the same channel length.  Now you can reference the channels with Ch("[1]/old") and Ch("[1]/new") in the channel calculator expression, assuming that the channel names are "old" and "new" respectively and that both are in the first group.  You don't need a row variable in the expression now, which is good because there's no way to iterate a row variable in a channel calculator expression.  The row iteration is implicit in the channel referencing Ch("[1]/new").
Brad Turpin
DIAdem Product Support Engineer
(5,351 Views)
Great solution.  Simple. Thanks!
(5,340 Views)
