DIAdem
VBSript to save an Excel file from Diadem
I realized a VBSript with DIADEM to pass data from Diadem to an Excel sheet.
All is OK but I don't know the function on Diadem to save automatically the xls file.
(5,854 Views)
Hi Franc
Please try this script
Set Excel = CreateObject("Excel.Application")
' Make Excel visible. Until now Excel was not visible.
Excel.Visible = True
' Open prepared DIAdem-Table in Excel.
Excel.Workbooks.Open(AutoDrvLibr & "Diadem.xls")
' Save File
excel.ActiveWorkbook.SaveAs "c:\test.xls"
More information could be found in the example of the DIAdem help (Userinterface>>Interfaces) and the VBA-Help of Excel (keyword OLE)
(5,854 Views)
Thanks a lot for your quick answer
(5,854 Views)
I'm having a bit of trouble with a simple task using the Excel OLE object in DIAdem.
I need to open a .csv (true comma separated) file to Excel
And then Save As .xls (true Excel 97-2003 format)
When I use the following code, the resulting file is named "result.xls" but is still comma separated inside. Is there a parameter for saving with a specified file format? I see there is such a parameter when the action is recorded in an Excel macro, but I couldn't figure out how to control that parameter in the OLE object.
Set oExcel = CreateObject("Excel.Application")
oExcel.Visible = True
oExcel.Workbooks.Open "C:\source.csv"
oExcel.ActiveWorkbook.SaveAs "C:\test.xls"
oExcel.ActiveWorkbook.save
oExcel.Application.quit
Using DIAdem 10.2/Excel 2007.
Thanks in advance for the help!
(5,360 Views)
Hi Fitz
The easiest way to find out the parameters you need is to record a macro in Excel. The parameter you are looking for ist the second parameter in the "saveas" command.
The second parameter must be xlnormal or  -4143. If you add the line autEdTypeLibAdd you can use the Excel constants by their name else you need the value.
' Microsoft Excel 11.0 Object Library
' C:\Programme\Microsoft Office\OFFICE11\EXCEL.EXE
Call AutEdTypeLibAdd("00020813-0000-0000-C000-000000000046", "1.5")
dim oexcel
oExcel.ActiveWorkbook.SaveAs "C:\test.xls" , xlnormal
'call oExcel.ActiveWorkbook.SaveAs ("C:\test.xls" ,-4143)
oExcel.Application.Quit
Hope this helps
Winfried
Winfried
(5,349 Views)
Winner,
Thank you for your fast reply.
-Fitz
(5,309 Views)
