DIAdem
VIEW "Layout Parameters" setting "Word wrap" value not persistent or saved in Desktop.DDD file
I thought the VIEW "Layout Parameters" setting "Word wrap" value is not persistent and does not seem to be saved to the DIAdem desktop "Desktop.DDD" file.  I think it should either be persistent or added to the saved parameters for the Desktop.DDD file.
The workaround is adding "View.Settings.UseMultilineLegend = 1" to some startup script which is fine, but I'd prefer it to be persistent upon changing it.
Long live DIAdem Word Wrap Legends!
(1,229 Views)
Accepted by topic author JuliaDawkins
Hi Julia,
" Word wrap" is part of the VIEW layout parameters. It's the same as "word wrap" in text object in VIEW or line width for 2D axis. These settings are saved with the layout and allow different layout settings for different applications.
Only properties very global parameters like "software rendering" or "display with antialiasing" are stored with the desktop file.
Greetings
Walter
(1,190 Views)
