DIAdem
Value from a function into a sub class
I Have a value from a function which I want into a Sub class.
Note: Text BlaBla are instead for program text)
Function yellow
Text blabla
Text Blabla
 strSessionCar=4
End Function
Sub apple
Text Blabla
 strSessionCar=4  (here i want to have the value from the "Function yellow")
End Sub
(5,694 Views)
Hi LVdummies,
Is this what you mean?  You assign the return parameter of a Function by using the Function name like it's a variable:
Call Apple()
Sub Apple
  Dim strSessionCar
  strSessionCar = Yellow("")
  MsgBox strSessionCar
End Sub
Function Yellow(Parameter1)
  Dim TextResponse
  TextResponse = InputBox("Enter Blabla Text")
Yellow = TextResponse
End Function
Brad Turpin
DIAdem Product Support Engineer
(5,673 Views)
