DIAdem
Variable types and variable use in SUD files
I'm going round in loops trying to get some code that used to work perfectly well in previous version of DIAdem but is now failing in 2019.
Originally, the code used a .vas file in which there were, amongst others, two variables as follows:
NoChan$ :   I   <0>
ChanAct$:   F (20) [16]
I'm afraid I can't find the reason for the $ sign. This is not used in the code as they are referenced using NoChan_ and ChanAct_(), respectively.
 In trying to remove the use of vas files I first of all tried to use the Dim statement in my main script as follows:
Dim NoChan, ChanAct()
This yields an error message from dialog editor (SUD), which says "Cannot link variables to the dialog box. You have specified the variables with the wrong type. This is the right type: Variant". This is weird for two reasons: firstly, you can't specify the type of variable in script and, secondly, they are variant by default.
I then checked my SUD file wherein I could see that the two variables were specified with types other than variant. I changed them to variant but to no avail.
I then wondered if the dialog box was not in the scope of the variables so I used the following at the head of my script:
Call GlobalDim("NoChan, ChanAct()")
 I got the same error message, so the problem seems to be one of type rather than scope.
NoChan is simple the number of channels in the data file and is a number I want to pass the Dialog_EventInitialize code. ChanAct() is an array that is to receive the text string from a series of list boxes in the Dialog_EventTerminate code. ChanAct() is then used in my main script.
Grateful for any guidance.
Simon.
(4,004 Views)
Accepted by topic author Simon_Aldworth
The best way to exchange data between VBS and SUD in DIAdem is a VBS CLASS.
You define such a class which contains at least the variables to be exchanged. Then you define a class object variable which is used as parameter for the SUD call.
In SUD you define a global SUD variable and assign the SUD parameter (class object variable) with it. In the dialog initialize event you assign the class content to the corresponding SUD object to initialize them.
If the dialog is going to be closed, you write back the content of the dialog objects to the corresponding SUD parameter (class object variable). This can be done either in the EventClick of the OK button orin the EventTerminate of the dialog.
Additional benefit: it is very easy to extend the SUD, now. You only need to:
  1. Extend the VBS class with a new variable and initialize it.
  2. Initialize the new SUD object
  3. Write back the content of the new SUD object
Attached you find a small example.
Greetings
Walter
(3,941 Views)
Hi Walter. That's terrific - thanks. So much more clearly explained than in the help files.
Just one question: you refer to the SUD variable as global, but I see just a regular dim statement in there. Did you mean global?
Regards.
(3,929 Views)
Hi Simon,
I meant SUD global, which means global for this dialog and usable in all events.
Yes, this is only a DIM in the beginning of the SUD script and before the first functions are defined.
Greetings
Walter
(3,925 Views)
