DIAdem
View Panel : Change color of data values in channel table
Is there a way wherein I can change the color of a particular data value or data block  in a channel in the VIEW panel and can this be done programtically? I am using DIAdem 2010.
Looking forward for your response
Thanks in advance
Priya
(3,766 Views)
Hi Pria,
There is no way to change the color of various cells in a VIEW table.  This can be done (for the text color, not the cell background) in a REPORT table with the help of a customer-defined UserCommand.  I can send you an example of this if having the display in REPORT would help.
If you had a newer version of DIAdem, you could embed a SUDialog in a VIEW area, and this SUDialog could have an XTable control that would enable you to show this type of display-- not easy, and not with DIAdem 10.2, but at least something to consider.
Brad Turpin
DIAdem Product Support Engineer
(3,759 Views)
