DIAdem
View numeric value as text from CAN dbc
I wonder whether it is possible to have in Diadem VIEW the option to display numeric value to corresponding text?
E.g. if a channel for a valve has the value 8 which is corresponding to "Valve closed" and this is defined in a CAN dbc.
Is there any way to show that data?
Thank you for your support!
(378 Views)
If you can generate a text channel with corresponding information you can select labels - from channel in the curve properties of the numeric channel in VIEW 2D axis system and with automatic alignment the text from the channel will be displayed at every curve point.
Holger Müller
DIAdem experience since 1996
Turn-key applications - Remote and on-site trainings - On-the-job training
| müller+krahmer GmbH | Koenitzer Straße 14, 07338 Kaulsdorf / Germany |
| Phone: +49 36733 / 2328 - 6 | Mobile: +49 160 / 287 7294 |
| Email: mueller@mueller-krahmer.de | Web: www.mueller-krahmer.de |
(305 Views)
