09-19-2018 12:31 PM - edited 09-19-2018 12:33 PM
Hello everyone,
is there an easy way to select only some values for View? I have an array of indexes and would like to plot several curves from the same channel between indexes. I plan making it a little bit interactive with band cursor so I don't want to create separate channel each time.
many thanks
09-21-2018 10:34 AM
Hey Adalbertus,
Could you elaborate on what you are doing? Are you loading data into your VIEW manually or using a script?
Are you looking to display the data only for the indexes in your array and then be able to scroll through that?
-Jelmer
09-21-2018 10:54 AM
Using a script. I want to split values from one channel into several areas. Currently I have a channels of values and an array of indexes bordering the regions I want to show (data from several channels go into the same area). Was thinking about creating simple procedure that I would call repeatedly, after shoving those curves you would use band cursor to select you area of interest. Simplest would be if I could just call view and tell it to show channel ABC from X to Y...
09-24-2018 02:55 PM
Hi Adelbertus,
The only way to display part of a channel in VIEW is to create a new channel that has only the part you care about and display all of the new channel. Really, only the statistics function in the ANALYSIS panel operates natively over a selected array index range. Otherwise you always end up creating a new channel. There are several suggestions in the DIAdemIdeas that would make this easier, if you want to "like" any of them...
Brad Turpin
DIAdem Product Support Engineer
