DIAdem
Virtual device DAC kernel parameters
Hello.
I need some advice on this problem.
We have 225 measurement channels but different calculations. Now it was necessary to add 10 calculations, but DIAdem reports this error. I tried to change the DAC kernel according to the instructions, but something worked and something didn't. It mostly reported a DLL error etc. Does anyone have a solution please? DIAdem 2019
Sorry, Google translate.
Martin
(2,274 Views)
Hello Martin,
can you provide more information about the issue? What is the exact error message? Are you using formular blocks for the calculations or do you use scaling blocks? Can you provide a small example that shows how your DAC scheme works? A few channels and calculations will be enough to see what you intend to do.
Regards
Rainer
P.S. You can ask your questions in German too.
(2,215 Views)
Hello
These are our DAC plans, the new one has the same number of input channels, only in one block the number has changed due to calculations (outlets ducts).
It is possible that this is the problem and it is certainly a simpler block for calculations than a script, which can be a problem with a larger number!
 Thanks a lot
(2,201 Views)
I think that you have to raise the numer of "Hardware Device Definitions" and maybe the number of "Hardware Input Types" in your DIAdem DAC configuration. That is at least what the error message says. If this doesn't help, I'm running out of ideas how to fix this issue.
Regards
Rainer
(2,179 Views)
Good day.
I was not at work and could not answer.
I tried this, but it didn't work, or Diadem reported a dll library error, so I left it. We probably have the maximum set.
I had to put part of the calculations in a special block and now it all works fine.
As soon as there were more than 100 values in one block, it reported an error.
Thanks for the advice anyway.
Have a nice day.
(2,114 Views)
