DIAdem
Want DIAdem to pull units out of my raw data and save as channel units
I am new to DIAdem so I appreciate any help offered.
My data (.txt) comes in so the first line is my desired channel name, the second line is the unit, and then the remaining lines are all my data. I am trying to configure the .txt import wizard so it takes the unit row out of the data and saves it as the unit in the channel property, for all channels (not all channels hae the same unit). How can I do this?
(4,284 Views)
Accepted by topic author jmcnally
jmcnally,
Change the row 2 type to Channel, then click next twice and you will be at the Channel Properties window. There, you can set the first row to name and the second row to unit.
Think of the rows you select on the File Structure window as Group Properties, Channel Properties, and data. Both the name and the unit are properties of the channel.
Hope this helps!
Michael
(4,262 Views)
Thanks so much Michael, very helpful!
(4,248 Views)
