DIAdem
Waveform can not be displayed in DIAdem
I open a tdms file in DIAdem,but  waveform cann't be displayed,I suspected to be caused by the data type. Is there any way to solve it?Thanks!
(1,302 Views)
Hello bhyy,
the data you load are not numerical, but string; you can see it on the label "ABC" before the channel name.
Moreover, the time channel (even if contains date & time information) is a string too. Means, Diadem doesn't understand it as "really time".
How the file was created/generated? Maybe there is an answer.
You can transform the values from string to numeric, and similar for time channel.
But: do you need it just once, or with other data files (with similar issue) too?
Depending on this, the code you need can be more or less general.
Greetings,
Vassili
(1,288 Views)
