DIAdem
Wavelet transformation in diadem
I have recorded Microphone data using Head Acoustic data logger and I have a UFF file with me. I would like to do a wavelet transformation with the available time domain data. Request someone to help me in this regard.
Rgs,
X. Ignatius
(3,152 Views)
I've been having a look into this, I do not think there are direct Wavelet Analysis options in DIAdem as mentioned by Brad in the post given below:
https://forums.ni.com/t5/DIAdem/wavelet-diadem/td-p/1043735
Brad is the Product Support Engineer for DIAdem so I'd consider his information to be reliable. Although this was back in 2009 so could have been implemented since. The main method they describe is using the LabVIEW Advanced Signal Processing VI's which provide wavelet transformation and potentially importing these into DIAdem which can be done as described in the below article:
http://digital.ni.com/public.nsf/allkb/D4947ACD289AE7A9862572D600603974
Have you been able to import the data itself?
Ed
(3,038 Views)
