DIAdem
What does DIAdem do to keep track of multiple versions of itself?
I am using an automation reference to open up DIAdem. I have 8.1 and 9.0 installed. If I run DIAdem 8.1 and close it, then the reference gives me 8.1. If then I run DIAdem 9.0, the reference gives me 9.0. So the computer must be keeping track of the program that was run most recently. How does it do this?
(3,866 Views)
It uses a registry key to save the current version
Ryan K.
(3,866 Views)
I don't think it uses a registry key. LabVIEW does, but there is nothing I can see in DIAdem where this happens. Which key/value is it kept under?
(3,866 Views)
I don't have two versions on this computer so I can't play with it to find the exact key, it's probably going to be under HKEY_CLASSES_ROOT\TypeLib\ somewhere, but it'll be under the Class ID rather than the name.
Ryan K.
(3,866 Views)
