DIAdem
What interpolation method does a Characteristic Diagram use?
Does anyone know what interpolation method is used when you create a Characteristic Diagram (3D contour chart) using a triplet of data? Interpolation implies that the fitted surface passes exactly through the data points. How is the rest of the surface calculated (interpolated)?
Am I right in saying the "Evaluation Points" in the diagram dialog box specifies a grid of x and y values for the surface to be evaluated at (by interpolation of the data points)?
I tried the online help, but it was a bit lacking in detail.
PorridgeMan.
(4,421 Views)
Accepted by topic author PorridgeMan
Hello PorridgeMan,
The SISPL algorithm is used for this.
The Smart Interpolating Spline Surface method combines a low computing time requirement with a high degree of smoothing quality. The method requires only a few settings. The method also accepts imprecise input data.
Greetings
Walter
(4,419 Views)
Thanks Walter.
Was I right about the Evaluation Points business? I suppose so, I can't think what else it could really be.
Do you know if there's any more detail on SISPL method somewhere, e.g. a knowledgebase article? I couldn't locate anything myself.
PorridgeMan.
(4,417 Views)
Hi PorridgeMan,
Yes, you are right. The SISPL algorithm is using a grid for the interpolation. Sorry, but I don't have detaild information about this algorithm.
One note : Depending on the measured data (which should be displayed) you can use a "pre-process".
Partial load structure
Specifies for the display mode Contour whether triplet data is distributed free or in a partial load structure. This setting specifies the interpolation mode of the z-values. If you enable this setting, DIAdem lays y-z-splines with regular interpolation points in y-direction through the points of every partial load. Then DIAdem lays x-z-splines through the interpolation points in x-direction. A partial load is compiled of points whose x-values are in a narrow tolerance range.
Use the PartialLoadTolerance property to specify the maximum deviation of the x-value in a partial load as a percentage of the complete x-area. Points whose x-values lie outside the tolerance belong to a further partial load. If a partial load has fewer than three points, DIAdem terminates the display.
Greetings
Walter
(4,414 Views)
