DIAdem
What is the format of a DIAdem import header file?
I have an application from which I want to export data to DIAdem. Where can I find documentation that describes the format of the import header file?
(4,285 Views)
Hi yahugh,
There is extensive documentation of the header file format on the DIAdem CD. It should be found in DIAdem 8.1CD\English\DIAdem\HEADER\dmheader.pdf.
I have also attached it to this post.
Gerardo Garcia
Applications Engineering
(4,285 Views)
The answer is perfect. Thank you very much. Do you have information on the TDM/TDX format?
(4,285 Views)
