DIAdem
When does Maximum and Minimum Channel Property get calculated?
I'm having an issue with the Minimum and Maximum channel properties being Null. I'm moving values from one channel to another in a dialog box and at this point the two properties become Null. But by the time I save the TDMS they have been correctly populated. Can I force DIAdem to complete this, before I continue in my code (I look at these values later in the code, and It's a problem if they are Null).
(6,473 Views)
Hi JDeckert,
Try the ChnCharacter() or ChnCharacterAll() functions after all the values have been moved.
Brad Turpin
DIAdem Product Support Engineer
(6,460 Views)
Hi! I wanted to ask you guys about the command ChnValMin. I am calculating thi minimum value of a Channel with 2 numbers. Both are numerical. But when I use the ChnValMin always gets me a NO VALUE. I tried using the ChnPropGet but it keeps not working.
Thank you for your help
Best regards
(5,877 Views)
This is from the help system. Have you tried it?
If the ChnValMin variable has NoValue, DIAdem has not yet calculated the value. Click Update Characteristic Values in the context menu of the Data Portal to update the value. Execute the command ChnCharacter to update the value in a script.
(5,853 Views)
According to the DIAdem 2012 Manual: Variable: ChnValMin
"If the ChnValMin variable has NoValue, DIAdem has not yet calculated the value. Click Update Characteristic Values in the context menu of the Data Portal to update the value. Execute the command ChnCharacter to update the value in a script."
You can do this by right-clicking on the data channel in the Data Portal and selecting Update Characteristic Values, as depicted in the image below:
Taylor B.
(5,852 Views)
Hi All,
You can force recalculation of a channel's characteristic properties (including minimum and maximum) with the ChnCharacter() command.  You can alternatively force calculation of only the minimum or maximum, etc. with the CCh() function.
Brad Turpin
(5,822 Views)
