DIAdem
Who can help me with "GraphObjChnClear(GraphObjName) " ???
Hello everyone,
I'm trying to delete a line in a graph. in diadem 8.1 and I'm using.
  Call GRAPHObjOpen("2DObj6_Curve1")
    D2CCHNX          ="Timer_15"
    D2CCHNY          ="Ped_strk5"
    D2CCHNY1         =0
    D2CCONSTX        =NOVALUE
    D2CCONSTY        =NOVALUE
    D2CAXISPAIRNO    =3
    D2CCURVETYPE     ="Line"
    D2CURVECOLOR     ="blue"
    D2CURVECOLORRGB  =50266112
    D2CURVESPECCOLOR ="red"
    D2CURVESPECCORGB =33554687
    D2LEGDRAW        =0
    D2LEGPDRAW       =0
    D2USECOMMONXCHN  =0
  call GraphObjChnClear("2DObj6_Curve1")
But it doesn't have any effect. Can someone explain me how can I delete a line of a graph.????
thanks in advance.
(3,964 Views)
Hi mvila
If you know the name of the axis system (eg. "2D-Axis1") and the name of the curve (e.g. "2DObj6_Curve1") you can use the following scipt to delete a single curve:
'------------------- Curve and axis definition ---------------------
Call
GraphObjOpen("2D-Axis1")
'------------------- Curve list -------------------------------
  Call GraphObjOpen("2DObj6_Curve1")
    D2CChnXName =""
    D2CChnYName =""
  Call GraphObjClose("2DObj6_Curve1")
Call
GraphObjClose("2D-Axis1")
Call
PicUpdate() 'Updates the report
If you want to delete all curves you can use GraphObjChnClear.
Call
GraphObjChnClear("2D-Axis1")
Call
Hope this helps.
Winfried
(3,962 Views)
Dear Winner,
Thanks for your help, It works but deletes all the curves, what I need is a function that only deletes an specific curve. And I thought that "GraphObjChnClear" is the function to solve that but it doesn't work (normally?).
Do you know how can I do that?
Thanks in advance.
(3,946 Views)
Hi mvila
As I show you in the first example you have to assign an empty string ("") to the x and y channel to delete a single curve.
Winfried
(3,940 Views)
I know that I used the following script ... but it don't causes any effect. Do you have another way to do that???
Obviously I checked that everi Object Name is correct.
Call GraphObjOpen("2DAxis5")
  Call GraphObjOpen("2DObj5_Curve2")
    D2CChnXName =""
    D2CChnYName =""
  Call GraphObjClose("2DObj5_Curve2")
Call GraphObjClose("2DAxis5")
Call PicUpdate() 'Updates the report
(3,937 Views)
Also I tried "GraphObjDestroy(GraphObjName)" but also don't work.
thanks in advance.
(3,936 Views)
