DIAdem
Who is supplier of IPC-9704 Strain Rate Analysis software for NI DAQ
estoy en busca de un software que haga el analisis the strain con graficos  basdo en los estandares de IPC-9704
(2,322 Views)
"IPC/JEDEC-9704" is a test / guideline.  See 6. Step 4 in  https://www.ni.com/en/shop/data-acquisition-and-control/strain-and-load/identify-and-characterize-da...   You should be able to get the maximum diagonal strain from the data acquisition data for each strain gage using DIAdem.   See page 50 of this report:  https://www.intel.com/content/dam/www/public/us/en/documents/guides/ch4-board-flexure-initiative-gui...      See also analysis procedure  https://pdfs.semanticscholar.org/dde5/bafe73a8b67a4e748a61769c3463ebf479d2.pdf
Contact me www.SavvyDIAdemSolutions.com if you need help customizing DIAdem to perform this analysis.
(2,227 Views)
