DIAdem
Why I can not open "open file" dialog when using FileNameGet?
For my script, I tried to open file using FileNameGet, but it doesn't work,what's wrong with this script?
Call WndShow("SHELL", "Normal")
Call  SUDDefLoad("PSA")
Do
  Call SUDDLGSHOW("Mainmenu")
  If DLGSTATE = "IDOk" Then
    If CUSTLASTCTRL="BtLoad" Then
       Call FileNameGet("DATA", "FileRead")
'     If DlgState ="IDOk" Then
'      Call DataLoad(FileDlgName)
'     Else DlgState = "IDOk"
'     End If
    End If
  End If
Loop Until DLGSTATE = "IDCancel"
Call ApplicationExit()
(4,377 Views)
Hello!
Because SUD doesn't support 'CUSTLASTCTRL'!
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,376 Views)
I forgot to say: There is no equivalent. You have to set a variable in the button event in SUD.
Matthias
Matthias Alleweldt
Twigeater?
(4,372 Views)
but you can use the variable "CustLastCtrl" and set it in the button event
greets Andreas
Volkswagen AG
Wolfsburg - Germany
(4,364 Views)
@Andreas: You can but beginning with DIAdem 10 it isn't documented anymore -> you don't know in wich future version it is eliminated.
Matthias
Matthias Alleweldt
Twigeater?
(4,360 Views)
