DIAdem
Wildcard for Access Query
I am trying to fetch records from Access database. I am having an error with the LIKE clause applied to the query. My query is something like below
Select A from tablename where B like '??ABCD??OR?'
The question marks is a wildcard, this can hold alpha numberic character.  When I tried executing this query directly in access it works fine. But when I execute this in DIAdem it shoots up an error telling "Exception Occured" when the record is fetched. I tried replacing the ? with * but this does not go through either. Can you help me out how to resolve this issue?
Thanks in advance,
Priya
(4,896 Views)
Hello Priya!
Assuming you use ADO to connect to Access you have  to use '_' and '%' as wildcards for the common '?' / '*'. This is nothing DIAdem specific, it is common for SQL!
I can't reproduce the error you got. How do you open the connection?
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,894 Views)
I am using the below code
 MdbName = "C:\Example.mdb"
 Set oAdoConnection = CreateObject("ADODB.Connection")
 oAdoConnection.ConnectionString = "Provider=Microsoft.Jet.OLEDB.4.0;Data  Source=" & MdbName & ";Persist Security Info=False"
 oAdoConnection.Mode = adModeReadWrite
 oAdoConnection.Open
 If oAdoConnection.Errors.Count Then
    msgbox err.description
 else
    Call MsgBoxDisp ("Connected to the Database     Successsfully","MB_NOBUTTON" ,"MsgTypeNote",,3,True)
 End if
  oAdoConnection.CursorLocation = adUseClient
  Set RecordSet = CreateObject("ADODB.RecordSet")
  RecordSet.ActiveConnection = oAdoConnection
  sqlCmd = "Select A from tablename where B like '??ABCD??OR?'"
  RecordSet.Source = sqlCmd
  RecordSet.CursorType = adOpenKeyset
  RecordSet.LockType = adLockOptimistic
  RecordSet.Open
  msgbox RecordSet.Fields("A")
  RecordSet.Close
I get the error at msgbox RecordSet.Fields("A"), the same query goes fine and fetches me the records in acess
(4,891 Views)
Thanks, I was able to run it using %, the reason why I dint try it is because when I directly used % in access no records were returned, but this works through DIAdem.
(4,889 Views)
Hi Priya,
Note that as Twigeater initial posted, the "_" SQL wildcard is identical in function to the Windows "?" wildcard, and the "%" SQL wildcard is identical in function to the Windows "*" wildcard.  The "%" SQL wildcard is not a one-for-one replacement for the "?" you were attempting to use.  The exact corresponding query would be:
Select A from tablename where B like '__ABCD__OR_'
Brad Turpin
DIAdem Product Support Engineer
(4,869 Views)
