DIAdem
Windows 11 impact on Diadem scripting
I have a quesiton. My work computer migrated from windows 10 to windows 11 and most of my scipts give me errors like : Error in <NameOfScript> (Line:10,Column:10): Expected ')'
Typical calculations i use in these scripts you can find below.
Call Calculate("Ch(""/Signal"")= " & x & " ",NULL,NULL,"Nm")
The issue appears to be the  " & x & " notation I use to introduce a value I declare in the script as Dim top
Can anybody explain me how a windows version can have impact on this ?
regards
Kevin
(812 Views)
Accepted by topic author KevinBisschops
I solved it by switching the region on my computer.
I noticed it went from USA to Netherlands.
One of the big changes is decimal notation but perhaps also other differences.
Anyways, all the scripts seem to work again.
regards
Kevin
(783 Views)
