DIAdem
Windows XP Permission Problem
Concerning:
I'm a systems administrator at the University of Rochester and am installing DIAdem as part of a Labview package on several Dell Optiplex GX260 PCs running Windows XP Professioanl [SP1].
I was able to install the application without incident and launch it from the local administrator login without a problem, but am running into problems [see below] when I try to run the program from a non-privileged login [normal domain authenticated user].
I am assuming that this is some kind of permission issue, but am unsure how to resolve this situation [short of granting normal users elavated privileges, which isn't practical].
I've tried adjusting the permissions on the Labview Program Folder and associated registry hive, without s
uccess.
Any constructive recommendations would be greatly appreciated.
TIA
Robert Lindholm
P.S. Here are the error messages, I have seen:
1) Launching DIAdem from nornal user login without adjusting Program Folder and Registry permissions:
Error
DIAdem Configuration-Drive "C:\PROGRAM FILES\ NATIONAL INSTRUMENT\DIADEM ACADEMIC 8.10" WRITE PROTECTED!
The application wouldn't launch at all...
2) Launching DIAdem from nornal user login after adjusting Program Folder and Registry permissions:
Error DIAdem
Error in (Row 59, Column 5): Variable is undefined: 'OdsDialog'
I click OK and then get the following message
Error DIAdem
The GPIDLL "GfSOds.dll" you need is not loaded.
The application still wouldn't launch at all...
(4,285 Views)
Robert,
In my experience, starting DIAdem once with the Administrator privileges after the install should allow any subsequent user without these privileges to run DIAdem without any problems.
Please starts DIAdem after logging in as an Administrator and then retry starting it with normal user rights.
If this doesn't help, please call me at (512) 683-5452 and we will look into other possible solutions.
Otmar
Otmar D. Foehner
(4,285 Views)
