DIAdem
Z-axis Unit in Joint Time-Frequency Analysis
Dear All,
could you tell me which unit should be on z-axis in calculated JTFA spectrograms?
My data is time (s) vs. velocity (mm/s).
Thank you in advance.
BR,
Krzysztof
(2,597 Views)
Hi Krzysztof,
I'm not fully sure I understand your question, should it be: what is the unit returned by the function for z-axis?
Could you please please tell me exactly which function you use?
In the meantime, let me add a link which you may find helpful: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x14vCAA&l=en-US
Mateusz
CLA,CTD,CLED
(2,554 Views)
Dear Mateusz,
Thank you for quick response. I am wondering which method is used to calculate JTFS. Is it Short time Fourier transform? If yes, then what is the unit returned by the function for z-axis?
I have described my problem in attached .docx file.
Krzysztof
(2,532 Views)
Hi Krzysztof,
Can you please confirm that you are using functions from Example Programs section of our webpage, which is:  https://forums.ni.com/t5/Example-Code/Joint-Time-Frequency-and-Order-Analysis-Tool-for-DIAdem/ta-p/3...
CLA,CTD,CLED
(2,530 Views)
