DIAdem
about "SubMatrix Level" care in AOP5
we can connect Diadem to our ODS Server by AOP5 Function.
However, Diadem does not call SubMatrix.
Is there any way we can use SubMatrix?
(1,585 Views)
Open the context menu in DIAdem Navigator and pick "Default Settings..."
and enable "Display the submatrices in tree
will show them in DIAdem Navigator.
and allow you to load them. In context menu there is also an option to load the submatrices instead of the measurement.
If you run the example script at
"C:\Program Files\National Instruments\DIAdem ????\Libr\Documents\Utils\ODS\ni_ods2dia\Ni_ods2dia_install.vbs"
in DIAdem you wil lget additional entries in context menu or a dialog when you drag and drop a measurement, that allows you to import more meta data and load without "ValueMatrix" rules.
(1,554 Views)
Good, Thank you. Your answer is what I was looking for. It was very helpful.
(1,541 Views)
