DIAdem
adding channels to the view
I am trying to add channels to a view using the vb method
view.sheets(1).Areas(1).DisplayObj.columns.add(iChannelNo)
When I do this it takes about 40 seconds to bring in 100 channels.
When I select the channels manually and drag and drop them into the
view, it only takes 1 or 2 seconds.
What am I doing wrong?
(3,554 Views)
There is a difference between interactively draging a whole bunch of
channels into the table and programatically adding the channels one
after the other in a VBS.
In your script, the table view is refreshed after each adding command
(even if the module view is not visible). This takes a certain abount
of time if there are numerous channels to be redrawn. You can use the
property view.autorefresh to change this behaviour. Have a look at my
script, it is generating a table of 100 channnels without refreshing
VIEW after each of them. This accelerates the action to some view
seconds.
wndshow "VIEW"
view.autorefresh = false
view.newlayout
view.activesheet.ActiveArea.DisplayObjType="ChannelTable"
for iCNo =1 to 100
view.activesheet.ActiveArea.DisplayObj.columns.a
dd(iCNo)
next
view.autorefresh = true
Ingo Schumacher
Application Engineering
(3,554 Views)
Hi Anonymous,
The speed also depends on whether you create the table columns one at a time or pass the method an array of channel numbers. Here is a VBScript that uses the latter "method".
Cheers,
Brad Turpin
DIAdem Product Support Engineer
National instruments
(3,554 Views)
