DIAdem
adding properties to channel groups : GroupPropCreate and GroupPropSet
I am trying to add properties to groups using visual basic script, in the Dataportal.
I found functions  GroupPropCreate and GroupPropSet, which appropriately create the properties : when I select a group, the new properties are created.
However, when I unfold the "Properties" item of the goup, only the default properties appear : Name and Description.
This behaviour is different from what happens when I create the properties from the UI, using right click on the group -> new -> Custom Property : then, the property created appears in the "Properties" item as well asin the list when the group is selected.
How can I get the same behaviour as the UI, programmatically ?
I am using Diadem 11.0
Message Edited by Vivian Brégier on 02-09-2009 06:05 PM
Vivian Brégier,
software developper
Atos Origin
(3,361 Views)
Hello Vivian,
Unfortunately this is not possible via script. The properties which shout pop up in the Dataportal are only configurable interactively.
Greetings
Walter
(3,344 Views)
