DIAdem
align data using maximum values
Hello all,
I have some data sets from torque measurements I took with a sensor connected to the pc. The data have different times because I make the test manually with a torque meter. I want to know if there is a way to align the different sets of data using the maximum values and center the graphs at the center of the graph. I have been looking at how to do this without luck.
Thank you all,
(2,895 Views)
Hello JoseAlfredoRdz,
Please have a look at this ANALYSIS function:
This function allows you to remove an offset and to map the channels on a new time channel in order to synchronize channels from different files.
Greetings
Walter
(2,565 Views)
