DIAdem
assign new name to root file using root properties
Hello There,
I ve,
Current File name = Test1.tdms
which has Properties such as :
     1. Lab = 123
     2. Load = Heavy
     3. Machine = 5
     4.Method = Fast
     5.Run = 2
my required New File name = concatenate of specified root properties spaced with underscore followed by the extension.tdms
i.e
New File name = concatenate [Data.Root.Properties("Lab"),Data.Root.Properties("Load"),Data.Root.Properties("Machine"),Data.Root.Properties("Method"),Data.Root.Properties("Run")] each property seperated by "_"
New File name = 123_Heavy_5_Fast_2.tdms
I need to perform this for multiple tdms files.
I ve attached a sample file
Please guide me thru this scripting process
(5,445 Views)
Hello rarun,
You can use the function DataFileRename:
Command: DataFileRename
This community example may in concatenating the text:
Change File Names in a directory with DIAdem
Samuel S.
www.ni.com/support
(5,423 Views)
Thanks Sam,
This is how I approached it, let me know if you have any better way to do it. (refer attachement Test1.tdms from previous post)
dim a,b,c,d,e, newname
a=Data.Root.Properties("Lab").Value
b=Data.Root.Properties("Load").Value
c=Data.Root.Properties("Machine").Value
d=Data.Root.Properties("Method").Value
e=Data.Root.Properties("Run").Value
newname=a+"_"+b+"_"+c+"_"+d+"_"+e
Call DataFileSave(newname,"TDMS")
Ques 1 : When I use 'DataFileRename' it provides this error ---- >  Operating system error :"-2"
Ques2 : I would like to keep certain length of my current file name and replace the rest with customized name
eg: current name = LR1634240_U4_Double_Loop_12_C_150331_154739.tdms
       newname = newname + _150331_154739.tdms
       The first part of the name is customized based on the above aproach
       The value of second part after '+' is unique to the file but the format of the second part is common for all other files.
How to perform this action.
Arun
(5,396 Views)
Hello Rarun,
1. You cannot use the variable "e", this is reserved by VBS
2. To concatenate strings, you must use &, not +
The following example may help with the second part of your question:
Also, here are resources regarding Regular Expressions in Diadem:
Regular Expressions
Sam S.
www.ni.com/support
(866) 275-6964
(5,372 Views)
