DIAdem
automatic change in all pages of the report
Hi Wasim90,
Yor channel „Zeit 2 Standard….“ Has a range from 113.27 to 113.37. In your axis system the scaling is from 673.15 to 673.375. There is no match. Can you provide the layout and the dataset?
Greetings
Walter
Message 11 of 35
(1,784 Views)
Hi Walter
the normal file is only up to group 2 . From group 3 (low-pass filter) is after the automatic evaluation.
from group 4 ( Events -Filter -a-5-3 X ) are the results of an event search.
for each event there is a diagram in the layout.
I can't send the file.
What format should I send it in?
Greetings
Message 12 of 35
(1,777 Views)
Sorry
that was my mistake, I have shown other diagrams with the properties, here is the right one.
we can calculate the difference in the legend
here :113.37-113.27=0.1S=100ms.
Greetings
Message 13 of 35
(1,773 Views)
You can use this here:
@@str(Data.GetChannel(CurrChnNo).XRelation.Maximum-Data.GetChannel(CurrChnNo).XRelation.Minimum, "d.dd")@@
Greetings
Walter
Message 14 of 35
(1,766 Views)
 Hi Walter,
i tried it, it only works on the first one, it seems it always takes the first time of each group.! although I make an x-axis for each event.
is there maybe a solution for this?
Thank you very much
Greeting
Message 15 of 35
(1,762 Views)
Hi Wasim90,
On my PC it works fine for more than one axis system. If you send me the layout and dataset I can check it.
Greetings
Walter
Message 16 of 35
(1,756 Views)
Hi Walter,
I tried to send it but got an error, maybe it's because of the file format!
in what format should I upload it?
I hope these pictures can show something.
Message 17 of 35
(1,747 Views)
Hi Wasim90,
a ZIP file should work.
Greetings
Walter
Message 18 of 35
(1,741 Views)
Hi Walter,
ok Thank you
Report
Greetings
Message 19 of 35
(1,736 Views)
here the normal file after the evaluation
Message 20 of 35
(1,732 Views)
