DIAdem
automatic report from a script
I am trying to fully automatize my DIAdem reports (mainly composed of 3D characteristic diagram) by means of a vbs script but I don't find the commands/properties to set the following parameters:
- x, y z scaling
- boundary curve
- isolines start value, end value, step
- shading
...... and more if possible
I have found in the DIAdem's help a script which can generate a 2D plot (see the file attached) and I am trying to adapt it. Is it possible to use the same kind of structure for a 3D plot?
I also attached an example of plot from my report. Would you have any example of script to do that?
Thanks in advance for your support.
Jérémy
(5,647 Views)
Hello all,
I have finally found how to create a new characteristic diagram, but I have to surface overlayed and I would like to remove the second one (I only want to display the isolines). Basically, I just want to uncheck the box "surface" shown in the picture attached.
Thanks for your support
Jérémy
(5,609 Views)
