DIAdem
average and addition in chanell
hi;) i hope this time you will help me too:)
i have some new problem in my work, i cant do some fuction
1. how i can calculation sum ( total) for all chanel. so i want have in one cell in next chanell sum of all  previosu chanell
2. how i can addition chanell, in result chanell i want have  sum but only until the same line of data, hmm it is hard to explain for me, for example in cell in result chanell in line 10 i want have sum for 10 initial line of data chanell
3. how i can calculation  average ( arithmetical average- the most simply average, i dont know if it is good name  but in my language the most simply average call arithmetlical 😉 ) for all chanell, what fuction should i use
i will be  grateful for all ideas and help. (sorry for my poor english 😉 )
(3,414 Views)
Hello!
You should have a look at the StatBlockCalc command. It should be the solution for all three problems. Details:
  1. You can define a list of input channels and the result for every calculation (sum, arithmetic mean) can be in seperate result channels.
  2. You can define the rows to add. First you have to find out the row index. Have a look at the ChnFind command for this task.
  3. Set StatSel(6) true in the StatBlockCalc
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,397 Views)
