DIAdem
average of graph in diadem
Hello!
We made experiments with Interfacial Shear Rheometer (ISR) and the results are the best in scatter graph view, but sometimes for the same x parameters we have more different Y values.
How can we make the average of one line, please?
See You !
Mr. Balazs
(5,106 Views)
Hi Mr. Balazs,
You haven't really given me enough information to know the exact nature of your difficulty.  If you have N pairs of XY cartesian points where X is the same for all of them, and you want them to be averaged together into just one XY pair with that X value, then you could try the Linear Regression function in the Curve Fitting palette of the ANALYSIS panel.  If your problem is that you can't graph all the Y values because your X channel is shorter than your Y channel, then you need to reshape the X channel so that the repeated X value appears on the same row with each Y value that occurred for that X value and so that the X and Y channels each have the same number of values.  If your curve is not linear, then you might also try a different curve fitting function such as a polynomial approximation or a spliine fit.
Brad Turpin
DIAdem Product Support Engineer
(5,078 Views)
Thank You for your answer!
But I think I did not explain completely my problem.
Well, our length of x-scale is the same as y-channel.
And we do not have only one x-value.
We have around 10 different x-values, and around 50different y-values. Each x-value contains around 5 different y-values. And thisis only one graph! The outlook of our graph with the spot /scatter/ shape canbe seen on the following:
http://href.hu/x/cjpf
How could weaverage these much points (many of them belonging to the same x-channel) into anice, linear/or polynomial/ one-line curve?
Thank you foryour answer!
Regards!
Balazs
(5,050 Views)
Hello Krakk1,
You should be able to use the Regression function located under analysis then curve fitting. From there you can select your X channel and your Y channel that you wish to use to calculate the regression line. This will create a single regression line for all of your points. Let me know if this helps out and have a great day!
Best Regards,
Adam G
(5,014 Views)
