DIAdem
axis scaling
It's ok im sorry it was only bad axis's name. 🙂
Message 11 of 15
(1,355 Views)
In report window, when i change manually the y scale, the x axis graduation disapear.
Do you have an idea about my problem??
Message 12 of 15
(1,347 Views)
i understood, the problem is:
the graduation are not fixed on axis. how fix the graduation on axis?
Message 13 of 15
(1,344 Views)
I need 3 TV, string vector variable but there only exist one TV variable.
How can i create some string vector variable???
Please
Thank you.
Message 14 of 15
(1,333 Views)
Hi c.reverte,
There are several different types of global variables you can use in DIAdem, but I think what will work best for you will be to create two new TV2 and TV3 variables with the following VBScript commands:
Call OdsValAlloc("TV2" , "ODS_TYPE_STRING", 10)
Call OdsValAlloc("TV3" , "ODS_TYPE_STRING", 10)
You will need to do this every time you launch DIAdem,
Brad Turpin
Message 15 of 15
(1,319 Views)
