DIAdem
bandwidth
Hello maybe someone can help me with my problem. i try to do bandwidth of forces in my diadem script . i need to do something which can calculate betwen max and min of all points(variables) in one channel in my analyse
(5,442 Views)
Hi derek,
As best as I can make out from your question, all you need to do is request the "Minimum" and "Maximum" properties from the channel in question and subtract the "Minimum" value from the "Maximum" value.  This will give your the full range of that channel, from global min to global max.  Please explain further if you meant something else.
You can get the same information with a single function call, if you prefer, which will recalculate the range:
Call CCh(Channel, 3)
Brad Turpin
DIAdem Product Support Engineer
(5,393 Views)
Ok but if i want to makea bandwidth whitch i use in reports witch can do this between 2 single variables occurring after yourself .
And when i go with cursor the curves i can look at the bandwidth between them
Is this is possible ?
(5,151 Views)
Hi darek,
Yes, that is all possible with DIAdem customizing.  You'll need to provide more details how you want the user to interact with DIAdem before we can help you realize your goals by customizing DIAdem with scripting.
Brad Turpin
(5,129 Views)
Ok just like in my picture i need to find a bandwidth between two single variables  occurring after yourself  MIN and MAXand this variable will be mine bandwidth witch i need conclude in my script and report
ANd  i need to find value of bandwidth which is most popular or mediana or average value
(5,111 Views)
Hi darek,
You use several terms in an unusual way.  Let's start by trying to nail down what you mean by the following terms in your messages:
1) Bandwidth.  This typically refers to a range of frequencies-- is that what you mean?
2) Variables.    DIAdem variables are invisible in VIEW and REPORT but can be linked to with @@ expressions.
3) Yourself.     That would be "me", I suppose, but I don't understand what I have to do with anything here.
4) Popular.      I'm guessing you mean "which happens most often", not who's trending on Twitter-- right?
5) Mediana.     I suppose you're talking about the "median".  But what is a "median bandwith"?
Brad Turpin
(5,090 Views)
