DIAdem
butterworth
I would like to know which calculs are performed when  a signal (DIADEM DATA) Is filtered with the crash analysis function.
What is the mathematical function used to get the filtered outpul signal (algorithm or FFT +calcul and inverse FFT)?How each individual output values are calculated from the input values?
Thanks for your help.
Regards.
(3,260 Views)
Hello lpicard!
You can find detailed information in the PDF 'Crash Analysis Criteria Description'.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,255 Views)
