DIAdem
calculation problems
Hello Norman,
In general Brard's script is OK. It is necessary to declare the variables which are used in the Calculation command as global. The command works fine if you integrate the variable zahl3 in the command string.
Dim zahl1, zahl2
GlobalDim "zahl3"
GlobalDim "zahl4"
zahl1 = 4.5
zahl2 = 3.7
zahl3 = zahl1+zahl2
zahl4 = zahl3*zahl1
Call Calculate("Ch(""[2]/Test"")=zahl3",NULL,NULL,"")
You can easily get the syntax if you switch on the record made in SCRIPT and then run the command in the formula calculater.
Greetings
Walter
Message 11 of 12
(981 Views)
ah thanks. i thought i hade to integrate the variable with "& zahl4 &"
thanks for your help.
Message 12 of 12
(979 Views)
