07-31-2007 06:55 AM
07-31-2007 11:04 AM
Hi FHM,
If LabVIEW spawns the DIAdem instance through ActiveX, then when the VI stops the child DIAdem instance exits too. This is standard ActiveX dependency, and there's nothing we can do about it. However, if DIAdem is already launched and LabVIEW just dials into it with ActiveX, then that DIAdem instance will remain when the VI stops. So one simple solution is to just start DIAdem prior to running your ActiveX VIs.
Alternatively, you can try running the "NI DIAdem Report Wizard.vi" in the LabVIEW-DIAdem Connectivity VIs or the "DIAdem Report.vi" that ships with LabVIEW (on the Express>>Output palette). Both of these VIs create a stand-alone DIAdem instance by invoking DIAdem from the command line with the DOS extension to run a particular script. When DIAdem is launched from DOS it is a stand-alone instance that will continue even after the application that called the DOS command exits.
Hope that all helps,
Brad Turpin
DIAdem Product Support Engineer
12-04-2007 09:54 AM
12-18-2007 03:27 AM
12-18-2007 03:46 AM
Hello themad,
thanks for your question. Yes I did so and it worked.
12-18-2007 03:49 AM
12-18-2007 04:14 AM
