DIAdem
call function threw menu
I would like to create custom menu , so I use :
Call MenuItemAdd(strPanel,menuPos & ".1.1","MenuItem","Test", "call Do_Test()")
It doesn't work (Type mismatch error), seems to be an error in the "call Do_Test()", to call my Do_Test function. Any suggestion ? Need to use ScriptStart ??
Thank's in advance.
(3,774 Views)
Hello!
Have you registred the script containing Do_Test as a global script extension (via 'ScriptCmdAdd' or the DIAdem Settings)? If not do it or use ScriptStart instead of the simple call.
Matthias
Message Edited by Twigeater on 07-18-2008 03:45 PM
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,773 Views)
