DIAdem
can labview run/start scripts in diadem
I have a script written in Diadem that uses config files to load the data and then add it to a report. It then exports the report in a pdf format. I would like to run this script with labview so I can automate this when new log files are created.I have used the report template VI but I have csv files not signal files plus I want to be able to export the reports automatically
(4,273 Views)
Hi chandler,
I suggest you to follow this link, or this one if you use earlier version of LabVIEW.
You'll find an attached vi as a very simple example :
Mathieu
(3,203 Views)
