DIAdem
can't add new channel - DIAdem out of memory
i've loaded a huge chunk of data to my DIAdem. I've got 92 Groups with approx. 740 Channels each and a Channellength with about 1000.
Now i can't do anything in DIAdem Smiley Happy
When i try to calculate a channelaverage betwenn two channels, i get the message "Die gewünschte Kanalmenge konnte nicht angelegt werden". I even can't do ChnLinGenImp.
Is there a way to increase the memory allocated to DIAdem with a parameter? Or is this just too much data at all...
Here are my systeminfos:
DIAdem 12.0.1 SP1b
RAM Usage 1.410.700K
OS: Win7 Enterprise SP1 64Bit
CPU: i5 M520 @ 2.40GHz
RAM: 4 GB
With best regards
Martin Kozlowski
(5,881 Views)
Accepted by topic author MartinKozlowski
Hi Martin,
DIAdem has a maximum global channel count of 65335 (2^16).  Based on the numbers you provided, it sounds like you're bumping up against this hard limit.  Would it be possible to load part of the data set into the Data Portal and perform your calculations in stages?
Brad Turpin
DIAdem Product Support Engineer
(5,869 Views)
Hi Brad,
thank you for the information.
I've got a script which loads only the required data. I was just testing with the complete thing and was wondering, if there's a way to push the limits.
With best regards
Martin Kozlowski
(5,845 Views)
